Lian Li PC-V359 Micro-ATX Modular PC Case Review
Lian Li PC-V359 Packaging
Lian-Li-PC-V359-Packaging-Box-Front
Keeping things simple, Lian Li has gone with a flashy box for the PC-V359. Which isn’t a big deal since they are mostly sold online. The front and back of the box are identical, providing the model number, and a small view of t he case.
Lian-Li-PC-V359-Packaging-Box-Side
Like the front and back, the two sides are identical as well, here more information is provides such as the specific model inside the box, which Lian Li only listed the Silver and Black models. In addition, a few of the specifications are listed just so anybody that happens to find it locally will know what the case is capable of.
Lian-Li-PC-V359-Packaging-Internal
Inside the box, Lian Li has packaged the PC-V359WA using four corner situated Styrofoam blocks. The case is stored inside a plastic bag to keep any potential moisture away from the case.
Lian-Li-PC-V359-Packaging-Accessories
Like most companies, Lian Li includes a number of accessories to complete a full system build into their case. To complete the build, they have included a little speaker, four rubber washers for 2.5″ drives, along with the appropriate four screws, a USB 3.0 to USB 2.0 header adapter, 2-pin to Molex fan power adapter, and a large number of additional screws. These screws consist of 13 hard drive screws, 9 motherboard stand-off screws, 5 power supply screws and 5 slim optical drive screws. The accessory pack also includes a multi-language, well detailed installation manual.
Lian-Li-PC-V359-External-Full-View-Protected
While most case manufacturers include plastic cling to protect side panel windows, Lian Li has kept the heavy duty paper protection on both sides of the top panel. The front window uses the paper protection on the inside and the common plastic cling on the outside.
