LEPA Prepares Liquid CPU Cooler With Ultra Slim Water Block
LEPA looks to be readying their own all-in-one liquid CPU cooler, the HDB120. LEPA plans to differentiate itself from other vendors of liquid CPU coolers by using an ultra slim block. The design itself consists of a 120mm fan mounted on a single 120mm rad, with an ultra slim water block which is only 12mm in height. The pump looks to be integrated into the rad with the tubing looking rather slim as well and exits the block from the sides instead of the top. Further details on the product are unknown such as the fans CFM, pump flow rate etc, however more details should surface once Comptex kicks off next week.
Allegedly HDB120 water-cooled heat sink configuration today’s thinnest water-cooled head, thickness of only 12mm, but more detailed parameters were not disclosed, need to ComputeX 2012 General Assembly in order to know.
