Kingston HyperX MAX USB 3.0 128GB External SSD Review
Test System
Test System
All tests were performed on an up-to-date install of Windows
7 Pro x64 with no
other applications running while using AHCI mode set through the BIOS. Synthetic Benchmarks were run with the OS loaded on a 240GB OCZ RevoDrive X2. The MSI Big Bang XPower motherboard uses an ICH10R south bridge chipset. In between every test, the drive was secure erased. As such, all results should be
indicative of optimal performance. All
components were set to their default speeds and are listed below:
Intel LGA 1366 Test Platform
Component Brand/Model Live Pricing
Processor
Core i7 930 (socket 1366)
Motherboard
MSI Big Bang XPower (socket 1366)
Memory
Corsair Vengeance 12GB
Video Card
MSI GeForce GTX 580
OS Drive
OCZ RevoDrive X2 240GB PCIE SSD
Power Supply
Corsair HX1000
Operating System
Windows 7 Pro 64-Bit
The drive is 100% backwards compatible with USB 2.0 although the bandwidth drops dramtically.
HYPERX IN USE LED
When operating though the USB 3.0 connection, the activity LED indicator
light shines blue and when connected as USB 2.0, the LED shines green.
HYPERX USB
We’ll have a look at some synthetic benchmarks and then move on to some real world tests to show how well it performs and some differences in speed between USB 3.0 and 2.0.
