Inateck FE2005 Review 2.5-inch USB 3.0 External Drive Enclosure with UASP
ATTO & CrystalDiskMark Synthetic Benchmarks.
ATTO v2.47
ATTO is one of the oldest drive benchmarks still being used today and is still very relevant in the SSD world. ATTO measures transfers across a specific volume length. It measures raw transfer rates for both reads and writes and places the data into graphs that can be very easily interpreted. The test was run with the default runs of 0.5KB through 8192KB transfer sizes with the total length being 256MB.
ATTO – Intel Z97 Platform:
OCZ Vector 180 480GB ATTO ATTO USB 3.0 Inateck FE2005
Benchmark Results: We didn’t get quite the same performance out of the OCZ Vector 180 SSD via the Inateck dock across the USB interface as we did with a direct SATA III interface but the numbers aren’t too far off and certainly faster than you’ll get from any hard drive from any interface.
CrystalDiskInfo 6.2.1 Readout:
CrystalDiskMark 3.0.3 x64 – Intel Z97 Platform
OCZ Vector 180 480GB CrystalDiskMark CrystalDiskMark USB 3.0 Inateck FE2005
Benchmark Results: Again, not quite the same performance on USB as SATA III especially in QD32 4K performance where the performance gap was tremendous. However, only enterprise type (i.e. server) applications hit this queue depth and other.
