ID-COOLING Releases Vapor Chamber CPU Cooler for Mini-ITX System
Jan. 19th, 2015 – ID-COOLING, a cooling solution provider focusing on thermal dissipation and fan technology research and production for over 10 years, releases a newly developed Vapor Chamber CPU Cooler for Mini-ITX system: IS-VC45.
When small PC systems get more and more power hungry and house much more top-tier hardware including the CPU, effective CPU cooling is in demand. With a vapor chamber base to draw heat immediately from the processor, IS-VC45 is able to handle TDP 130W CPUs. Measuring 949245mm, this cooler can fit into Mini-ITX systems easily.
High density aluminum fins are soldered to the vapor chamber base to help disperse the heat. Equipped with a slim 92mm FDB(Fluid Dynamic Bearing) fan, IS-VC45 can dissipate heat efficiently while keeping at a decent quite operation. The speed is regulated between 600 to 2500RPM with PWM function.
Using metal screws and back plate installation, this cooler will stay safely on your motherboard. Intel Socket LGA1150/1155/1156 and Socket LGA2011 are supported.
Price
MSRP for IS-VC45 is $44.99.
For more information about this product or any other products, you can visit www.idcooling.com.About ID-COOLING
Originally, ID-COOLING was a cooling solution provider focusing on VGA heatsink research and production for over 10 years. Accumulated extensive experience in thermal solutions, ID-COOLING releases a full set of product portfolio ranging from CPU cooler, VGA Cooler, Case fan and customized heatsinks, and SFF cases. Through years’ determination in thermal design, ID-COOLING developed many innovative cooling ideas, including heatpipe, vapor chamber, cold plate technology.
