Hitachi Touro Mobile Pro 750GB Portable Hard Drive Review
Unboxing the Touro Mobile Pro
Hitachi packs the Touro Mobile Pro in a nice cardboard and plastic case ready for retail sales.
The front of the box lets you see the sleek black drive and calls out the USB 3.0, 750GB capacity, and 3GB of free cloud storage.
On the right side of the box is an edge picture of the Touro Mobile Pro and a small graphic of the 3GB of cloud storage.
The left side of the box has the obligatory brief marketing text and system requirements.
Around back there is more marketing information highlighting the value of external backup and the included Hitachi backup software that allows you to access your cloud based files from any IP based device.
Opening the package provides you with a plastic clam shell holding the contents.
Included with the Touro Mobile pro are a 18″ USB 3.0 cable, a quick start guide, and a manual. The Touro gets its power from the USB cable so there is no other power source required making this a very mobile solution.
