ENERMAX Announces U.R. VEGAS USB Powered Rubber Fan w/ 18 LED Lights
ENERMAX just sent us over a press release that announced a new USB rubber fan in the companies U.R. VEGAS fan series that looks rather interesting. The U.R.VEGAS USB Rubber Vegas Fan is 120mm that pushes 52.5 CFM at 1250 RPM with a noise level of 21 dBA. This is a decent amount of airflow from a fan that hardly makes any noise! The real highlight of the cooling fan is the fact that it has 18 LED lights that can be run on 7 different light modes! Not bad for a 120mm fan that has an MSRP of just $20 and is due out next month.
![ENERMAX Vegas USB rubber fan ENERMAX Vegas USB rubber fan](https://www.legitreviews.com/images/news/2011/UR-Vegas.jpg)
Think outside the case. Cooling fan is no longer stationary and hidden inside the case. U.R.VEGAS breaks the rule by special designed magnetic skin pad and USB power. U.R.VEGAS provides mobility and flexibility with its magnetic skin pad. It can be attached onto case and moved easily to anywhere that needs extra cooling. With 18 LEDs, the U.R.VEGAS not only shines 4 times brighter than other fans, but also has 7 switchable lighting effects for users to enjoy the fabulous light show. U.R.VEGAS features patented Twister Bearing, which is a magnetic bearing type that does not deteriorate from abrasion like mechanical bearings, such as Sleeve or Ball-Bearings. Twister Bearing fans have long MTBF of 100K hours and low noise. For the safety purpose, a stylish fan guard is included with the package.
