EKWB Predator 240 AIO Liquid CPU Cooler Review
Overclocking with the Predator 240
Many of the previous tests we chose not to overclock beyond the turbo frequency in order to show you what your average user would see, but we did find the limits of this particular processor without going too extreme on the voltage and will start to include those results. The 4770k will be overclocked to a 4.3GHz turbo boost at 1.270 volts, which is over the stock 1.193v. To push this particular 4770k stably to 4.4GHz required well over 1.4 volts, which the performance gains of a 100MHz increase was not worth the risk from that huge bump in voltage. Also understand that every processor reacts differently to voltage adjustments, so some may run slightly cooler or hotter at this same overclock frequency.
I did not start overclocking the 4770k until after my Cooler Master Glacer 240L review, so not all coolers were tested under the increased stress of an overclock.
Again, ambient temperature at the time of testing is 74 degrees Fahrenheit. To record temperatures, we used Core Temp, logged the temperatures for 15 minutes or while each program was active, and averaged all 4 cores.
Not all coolers were overclocked and benchmarked with Prime95. There were times that the cooler was already too hot under stock frequencies, and risking failure of my CPU to obtain an unrealistic synthetic benchmark’s results was not worth it. Instead, x264 will be a much better and realistic example of taxing a CPU heavily.
Prime95
X264
3D Mark 2013
Metro Last Light
Sleeping Dogs
Overall Results: We found that the Predator 240 was able to handle our 4.3 GHz i7-4770k @ 1.270v quite well. Like the stock clock benchmarks, we found this cooler to be right in the middle of our other coolers that were benchmarked. Also like the stock clock benchmarks, a large chunk of the contenders around the Predator 240 were only off by tenths of a degree to a degree or two.
