EK Water Blocks Releases New L Series R2.0 Water Cooling Kits
EK releases new L series kits (R2.0)
EK KIt L360-R2
EK Water Blocks, Ljubljana based premium water cooling gear manufacturer, is excited to introduce the new updated (R2.0) line of EK-KIT L series value orientated, yet powerful liquid cooling kits.
These new and improved kits are direct successors of world renown EK-KIT L series kits. In new revision EK Water Blocks has again prepared three differently sized models: EK-KIT L120 R2.0, L240 R2.0 and L360 2.0, the only difference between them being the size of the radiator and the number of accompanied fans.
The EK-KIT L series Revision 2.0 liquid cooling kits are designed for all users who seek simple, yet quality and efficient all-in-one solution, assembled from selected market proven components.
The main change is from the original revision is the new high-performing EK-Supremacy MX UNI water block and a more reliable and powerful pump/reservoir combo unit with Laing/Xylem DDC series PWM liquid cooling pump. EK-Vardar high-static pressure fans are now also standard on every L series kit.
Kits are easy to install, use and maintain, a thorough installation manual is included. Further descriptions and specifications of individual items can be found in EK Webshop.
These kits are fully upgradeable with additional EK-Thermosphere, EK-FB, EK-FC or EK-RAM series water blocks and are compatible with the following CPU sockets:
– Intel LGA-775
– Intel LGA-1366
– Intel LGA-1150/1155/1156
– Intel LGA-2011(-3)
– AMD Sockets: 939, 754, 940
– AMD Sockets: AM2(+), AM3(+), FM1, FM2(+)
Made in Slovenia – Europe!
All kits are readily available for purchase through EK Webshop and Partner Reseller Network. Bellow are the specs and MSRP with VAT included:
Product EK-KIT L120 R2.0 EK-KIT L240 R2.0 EK-KIT L360 R2.0
CPU Water Block EK-Supremacy MX UNI EK-Supremacy MX UNI EK-Supremacy MX UNI
Radiator EK-CoolStream PE 120 EK-CoolStream PE 240 EK-CoolStream PE 360
Water pump / reservoir unit EK-XRES 100 DDC MX 3.1 PWM EK-XRES 100 DDC MX 3.1 PWM EK-XRES 100 DDC MX 3.1 PWM
Radiator fan 1 x EK-Vardar F3-120 (1850rpm) 2 x EK-Vardar F3-120 (1850rpm) 3 x EK-Vardar F3-120 (1850rpm)
Tubing EK-Tube ZMT Matte Black 15,9/9,5mm EK-Tube ZMT Matte Black 15,9/9,5mm EK-Tube ZMT Matte Black 15,9/9,5mm
Compression fittings EK-ACF Fitting 10/16mm – Nickel EK-ACF Fitting 10/16mm – Nickel EK-ACF Fitting 10/16mm – Nickel
Coolant concentrate EK-Ekoolant EVO CLEAR (conc.100mL) EK-Ekoolant EVO CLEAR (conc.100mL) EK-Ekoolant EVO CLEAR (conc.100mL)
MSRP (incl.VAT) 244,95 259,95 279,95
