EK Water Blocks Releases EVGA Classified SR-X & MSI R7970 Lightning Water Blocks
EK Water Blocks has announced the immediate release and availability of two new water blocks. First up is the EVGA Classified SR-X motherboard, which gets a full-board water block kit. It cools the Intel C606 southbridge, PLX PEX8784 PCIe lane splitter controller and finally the VRM / MOSFETS for both processors. There are two variants available, Nickel and Acetal+Nickel. So if you’re running with a fully decked out system using the big bad EVGA Classified SR-X motherboard and want top notch cooling, it looks like EK Water Blocks has you covered. The EK-FB SR-X kit in Nickel can be purchased for 134.95, while the Nickel+Acetal variant can be had for 129.95
We already reported on the MSI AMD Radeon HD 7970 Lightning Edition getting a block from EK Water Blocks last month, however now it is available for purchase. The block itself directly cools the GPU, VRAM and VRM for stability under high overclocks. The EK-FC7970 block features a very high flow design so it can easily be used with systems that have weaker water pumps. But EKWB doesn’t stop there, they have included the EK-FC link for each block so enthusiasts can easily connect up to four GPUs with the EK-FC Bridge & Link CSQ system. This particular design is only available in Acetal+Nickel and can be purchased for 114.95 directly from the EK Water Block e-shop. For more info and higher resolution images check our forums linked below.
EK Water Blocks, premium water cooling gear provider, has released two new water blocks – the EK-FB KIT SR-X for EVGA Classified SR-X motherboard and the EK-FC7970 Lightning for MSI’s premium R7970 Lightning graphics card.
