EK launches PWM variant of EK-DCP 4.0 water pump
EK Water Blocks, Ljubljana-based premium water cooling gear manufacturer, is proud to introduce the new EK-DCP 4.0 water pump with power management control. This new pumps allows pulse width modulation (PWM) control of rotation speed trough motherboard BIOS or dedicated fan controller.
The EK-DCP 4.0 PWM water pump is the ideal choice for all enthusiast water cooling systems and is compatible with the all standard water cooling system setups. This pump will easily integrate with the latest water blocks and can achieve up to 800L/hour with its compact, powerful and low-noise design.
Rugged, reliable and quiet, the EK-DCP pump will work silently to ensure your liquid cooling system operates at its peak and makes the most for your hardware overclocking potential. To improve the overall looks the product power cables comes pre-sleeved as standard.
PWM control allows for automatic pump speed regulation depending on your CPU temperature. Full performance on demand or whisper quiet operation in idle mode!
This product is compatible with EK-DCP 4.0 X-RES pump reservoir combo unit.
Technical specifications:
– Rated voltage: 12V DC
– Power consumption: 18W
– Maximum pressure head: 4.0m
– Maximum flow: 800L/h
– Maximum system temperature: 60C
– MTBF: 50.000 hrs at 25C
– Power connector: 4-Pin Molex- and 4-Pin PWM FAN connectorThe new water pump is readily available for purchase through EK Webshop and Partner Reseller Network and comes with a MSRP of 47,95 (incl. VAT).
