ECS Z87H3-A2X Extreme Motherboard Review
Intel Z87 SuperSpeed USB 3.0 Performance Testing
Thermaltake BlackX 5G SuperSpeed USB 3.0 Dock
There are a number of different Super Speed USB 3.0 host controllers out there. In order to know which ones perform the best we run a series of tests that will put the controller through the ringer and see how it comes out on the other side. Each of our motherboards uses a different Super Speed USB 3.0 controller and you can find the below.
MSI Z77A-GD65 Gaming Series Motherboard SuperSpeed USB 3.0 Performance
Testing of the USB3 was done using the “Thermaltake BlacX 5G Hard Drive Docking Station . The drive used was an Corsair Force GT 240Gb SSD.
ECS Z87H3-A2X Extreme USB 3.0 Performance
Benchmark Results: The ECS Z87H3-A2X Extreme SuperSpeed USB 3.0 performance wasn’t as dominating as the SATA III performance, but it wasn’t far off from the ASUS Z87-Pro. The Z87H3-A2X Extreme had a sequential read of 409.1MB/s, not quite up to the ASUS Z87-Pro speed of 421.2MB/s, but still solid. The ECS Z87H3-A2X sequential write was a little further back with a performance of 345.3MB/s compared to the ASUS performance of 373.6MB/s.
HD Tune Pro 5.00 is an extended version of HD Tune which includes many new features such as write benchmark, secure erasing, AAM setting, folder usage view, disk monitor, command line parameters and file benchmark.
Intel Z77 SuperSpeed USB 3.0 HD Tune 5.50 Read Benchmark Results
Intel Z77 SuperSpeed USB 3.0 HD Tune 5.50 Write Benchmark Results
Benchmark Results: HD Tune looks like a wash between the ECS Z87H3-A2X and the ASUS Z87-Pro. There is no discernible difference between their performances.
