Deepcool Gamer Storm Dracula VGA Cooler Review
Legit Reviews Intel Core i7-3960X Test System
System specs
Here is a short list of the parts that make up the Legit Reviews Core i7-930 test system:
Intel Test Platform | ||
Processor | Intel Core i7 3960X | Click Here |
Motherboard | Intel DX79SI | |
Memory | Corsair Vengeance LP 16GB DDR3 1600MHz | Click Here |
Video Card | EVGA GeForce GTX 480 015-P3-1480-AR | |
Hard Drive | Corsair Force GT 90GB SSD | Click Here |
Power Supply | NZXT HALE90 750W | Click Here |
Chassis | Thermaltake Chaser Mk-1 | Click Here |
Operating System | Windows 7 Professional (64bit) | Click Here |
Test System Detail
The CPU we are using is the Intel Core i7-3960X LGA2011 processor. We will test with two configurations: Stock and Overclocked. Both will have Hyper Threading and Turbo modes enabled. For the backbone of the system we have the Intel DX79SI motherboard. We have also outfitted it with a 16GB (4x4gb) kit of Corsair Vengeance LP DDR3 1600MHz RAM. Drivers used for the motherboard are as follows:
Motherboard Drivers:
- LAN: Intel PRO Network Connections LAN Driver version 16.7
- Audio: Realtek ALC Audio Driver version 6482
- Chipset: Intel Chipset Device Software version 9.2.3.1022
- USB3: Renesas Electronics USB 3.0 Driver 2.1.27.0
- BIOS Version: 0380
The video card we are using is an EVGA GeForce GTX 480 015-P3-1480-AR and is running ForceWare 290.53.
For the main drive we have a 90GB Corsair Force GT SATA3 SSD running firmware 1.3.3.
Testing Procedure
To test the coolers the video card will be left idle at the desktop for 30 minutes and the temperature will be recorded. Then it will run at full load with Furmark benchmark full screen at a resolution of 1600×1200 with dynamic background and the temperature will be recorded. There will be 2 levels tested with our EVGA GTX480 the stock setting for 701mhz on the core, and 924mhz on the memory. Then overclocked to 800mhz on the core and 975mhz on the memory. The thermal paste used on all coolers will be Gelid GC Extreme and the room temp at 21*C.
