Danger Den Releasing All Copper Water Block For GeForce GTX 480 GPUs
I just noticed that Danger Den is coming out with a sweet looking all copper water clock for the NVIDIA GeForce GTX 480 graphics card that will keep it nice and cool with the right water cooling loop. Danger Den thinks that the all copper block will be in the $140-150 price range, so it won’t be cheap. Danger Den will also have a nickle plated top with copper base version and then a third water block that is all nickle. Each will cost more because of shipping and nickle plating costs. Danger Den should have the all copper version ready by the end of this week, which is well ahead of the public release of the graphics card. If you plan on buying a GeForce GTX 480 and want it to run cool then water cooling is certainly the way to go!
There will be three versions to start. The All Copper will be available first with the nickle versions in 1-2 weeks.
- All Copper
- Nickle Top Copper Base
- Nickle Top and Nickle Base
