CyberpowerPC Zeus Mini-I 780 mITX System Review
SiSoftware Sandra 2013
Sisoftware Sandra 2011 SP5
The Sisoftware Sandra 2012 SP3 benchmark utility just came out a few weeks ago and we have started to include it in our benchmarking. Sandra 2012 comes with support for Virtualisation (Virtual PC/Server, Hyper-V, VMware) and GPGPU (OpenCL, DirectX 11 DirectCompute), but today we will be using the program to look at memory and CPU performance!
SiSoftware Sandra Benchmark Results
Benchmark Results: The CYERPOWERPC Zeus Mini-I 780 wasn’t quite up to the performance of our usual test bench. The Zeus Mini-I 780 is running a pair of G.Skill Ripjaw 1866MHz memory modules while I run a pair of Corsair Dominator Platinum modules at 2133MHz. The good news is that you can configure the Zeus Mini-I 780 with a set of Corsair Vengeance 2133MHz modules if you are so inclined!
Benchmark Results: In the Sandra Processor Arithmetic benchmark the LR test bench has the slight edge due to the faster memory that’s running on it.
Benchmark Results: The CYBERPOWERPC Zeus Mini-I 780 took the lead in the Sandra Multimedia benchmark with an aggregate multimedia performance of 350.16 frames per second compared to the LR test bench at 346.42 FPS.
Benchmark Results: The Legit Reviews test bench took the lead once again with a cryptographic bandwidth of 6.85GB/s while the Zeus Mini-I 780 hit 6.28GB/s.
