Corsair Vengeance Pro Series 16GB DDR3 1866MHz Memory Kit Review
The Test System
Corsair Vengeance Pro Installed
  • Intel Core i7 4770k Quad-Core Haswell CPU
  • Stock Socket 1150 CPU Cooler
  • 16GB Corsair Vengeance Pro 1866MHz Memory
  • GIGABYTE Z87X-UD4H Motherboard
  • EVGA GTX 570 Classified Video Card
  • 2x 120GB Samsung 840 Pro SATA III 6Gb/s SSDs in RAID 0
  • Thermaltake Pure Power 680w Power Supply
  • Windows 7 Professional Operating System
Intel Z87/LGA1150 Platform
The Intel Z87 platform that we used to test these memory modules was running the GIGABYTE Z87X-UD4H motherboard with BIOS version F7 that came out on 08/05/2013. The processor used, the Intel Core i7 4770k, was just using the stock frequency of 3.5GHz with turbo boost enabled, which can boost it up to 3.9GHz.
Corsair Vengeance Pro CPU-Z
Up next I will run a couple benchmarks against these modules to see how well they perform!
