Corsair Unveils Carbide Air 540 Case With Side-by-Side Chambers
Corsair today announced the Carbide Series Air 540. Both cases incorporate innovative and unique features for superior cooling and quiet operation. The Carbide Series Air 540 is designed with a wider form factor with two “side-by-side” chambers and a Direct Airflow Path™ layout. This unique design helps the case deliver best-in-class cooling at incredibly low noise levels.
The main chamber of the Carbide Series Air 540 houses the motherboard and hot-swap 3.5” drives for superior drive cooling and quick swapping. The second chamber holds the power supply, SSDs, and 5.25” drives behind the motherboard tray. The separate compartments make building a breeze and provide cleaner cable routing and superior cooling for system devices. In addition, layout in each chamber is optimized to limit obstructions and streamline airflow from the intake fans to the hottest PC components, resulting in lower temperatures and noise levels. The Corsair Carbide Series Air 540 has a suggested retail price of $139.99.
Corsair Carbide Air 540 PC Case Features:
- Support for Mini ITX, Micro ATX, ATX, Extended ATX motherboards and ATX power supplies
- Eight tool-free expansion slots that supports cards lengths up to 12.5” (320mm)
- Mount points for six 120mm or five 140mm fans (or 240/280mm radiator on top and 360/280/240mm radiator in front)
- Two 5.25”, two hot-swap 3.5”, and four 2.5” tool-free drive bays
- Removable front magnetic low-restriction dust filter
- Built-in cable routing cutouts with grommets
- Two USB 3.0 ports plus headphone/mic jacks on front panel
- Oversized flush-mount window
- 16.5″ (407mm) deep x 17” (432mm) wide x 18″ (457mm) tall
