Corsair Hydro Series H100 CPU Water Cooling Kit Review
Prolimatech Super Mega CPU Cooler
System specs
Intel Test Platform
Component Brand/Model Pricing
Processor Intel Core i7 930 Click Here
Motherboard Intel DX58SO Click Here
Memory Kingston DDR3 3GB 1333MHz ValueRAM Click Here
Video Card EVGA GTS450 Click Here
Hard Drive Western Digital 250gb SATA Click Here
Power Supply NZXT HALE90 750W Click Here
Chassis Cooler Master HAF 912 Click Here
Operating System Windows 7 Professional (64bit) Click Here
Test procedure
To test the coolers the system will be left idle at the desktop for 30 minutes and the temperature will be recorded. Then it will run at full load with Prime95 Blended test for 30 minutes and the temperature will be recorded. There will be 3 levels tested with our Core i7-930 clocked at a stock 2.8 GHz, a mild OC of 3.5 GHz and a high OC of 4.0 GHz. All temps will be recorded with CoreTemp, and the temp reading from all 4 cores will be averaged. The thermal paste used on all coolers will be Gelid GC Extreme.
Coolers Tested
