Corsair Graphite 600T Case and Airflow Pro Memory Preview
Corsair Airflow Pro
Corsair was also showing off a system that was running their new Airflow Pro that is used in conjunction with Corsair Dominator modules equipped with DHX Pro that has been on the market for roughly 6 months now. The Corsair Airflow Pro is an update to the original DDR1 Pro memory series that had activity LED lights on them to show off if your memory was actively being used. The new Airflow Pro now shows both memory temperature and memory activity thanks to some custom components that are used on the memory kit.
Let’s listen to Corsair describe the Airflow Pro for us. Sorry for the bad lighting in the window letting too much light in!
The Corsair airflow looks very slick and all the LED lights look sweet inside your system, but be sure to have a case with a window on it if you want to see them!
Here is a quick look at a Corsair Dominator DHX Pro that is needed for the Airflow Pro to work. If you don’t have the little connector on the edge of your memory modules the Airflow Pro won’t work as it reads the data straight from the module rather the system bus.
As you can see a 4-pin fan header powers the Corsair Airflow pro LED display and another 3-pin fan header powers the Airflow memory cooling fan. The gray cables are are attached to your memory sticks. Corsair said that all of the cables will be black in color when the retail models arrive later this summer.
That isn’t all Corsiar showed off as they also had a very cool fully modular power supply to show off!
Let’s take a look at it!
