Corsair Flash Voyager GTX 128GB USB 3.0 Flash Drive Review
Test System
Before we look at the numbers, lets take a brief look at the test system that was used. All testing was done on a fresh install of Windows 8.1 Pro 64-bit and benchmarks were completed on the desktop with no other software programs running. Windows has had the power option set to high performance.
Intel Z97 Test System
The Intel Z97 platform that we used to test the Corsair Flash Voyager GTX 128GB drive was based around the ASUS Z97-A motherboard with BIOS 1008 that came out on 5/29/2014. The Corsair Dominator Platnium 8GB 2133MHz memory kit was set to XMP 1.3 memory profile settings, which is 1.65v with 9-11-11-31 2T memory timings. The Corsair Neutron GTX 240GB SSD was used as the primary drive (uses 19nm NAND and M310 firmware).
Intel Z97 Test Bench
Intel LGA 1150 Test Platform
Component Brand/Model Live Pricing
Processor
Core i7 4770k
Motherboard
ASUS Z97-A
Memory
Corsair Platinum 2133MHz 8GB
OS Drive
Corsair Neutron 240GB
Power Supply
Corsair AX860i
Operating System
Windows 8.1 Pro 64-Bit
CrystalDiskInfo 6.1.14 Readout:
For the Plextor M6e 256GB M.2 PCIe SSD, the readout on CrystalDiskInfo 6.1.14 shows that APM, NCQ, S.M.A.R.T. and TRIM are available on the controller. The firmware version that we are running at the time of testing was S9FM0.17. It should be noted that the firmware could potentially be updated, but Corsair has no plans on releasing firmware updates for USB flash devices unless a critical issue is found.
voyager-gtx
Let’s have a look at the performance!
