Corsair AX1200i 1200W Power Supply Review
Unboxing the power supply
We received the AX1200i supplied
inside a large cardboard box, inside which everything is very neatly packed and
well protected. Artistically, Corsair went with a simple dark theme to match
the “professional” class of the product.
Corsair fit a vast amount of
information on the rear side of the box, including a detailed list of all of
its features, electrical specifications and efficiency/temperature figures.
For such a classy product, the
bundle definitely is somewhat disappointing. The purchaser of this unit will
receive the standard A/C power cable and standard mounting screws, a few
standard cable ties and a basic black and white manual. There is also a nylon
bag which holds all of the unit’s cables, since its a fully modular design.
The Molex, Floppy and SATA cables are all-black, flat cables. The rest of the
cables are sleeved but Corsair still used all-black cables beneath the
sleeving, which definitely looks much better. Unfortunately there are no other
extras, not even a few cable straps.
