Corsair Announces Hydro Series H55 CPU Cooler & Updated H60 Water Coolers
Corsair today announced an updated version of the award-winning Hydro Series H60 liquid CPU cooler, and the new Hydro Series H55 liquid CPU cooler. The Hydro Series H55 is an update to the hugely respected Hydro Series H50, and is based on the latest, 4th generation cold-plate design. The updated version of the Hydro Series H60 takes advantage of the latest cold plate, manifold and fan technology to further increase performance and reduce noise levels. In addition to the new cold plate and manifold design, the Hydro Series H60 also utilizes larger diameter tubing, which increases the coolant flow rate and performance. The new composite rubber tubing makes installation easier, but retains the low-evaporation rates of the older, more rigid tubing, guaranteeing a long lifetime. The Hydro Series H60 also introduces a new magnetic mounting bracket, which makes it simple to select the correct motherboard socket format. The updated Corsair Hydro Series H60 runs $79.99 and the new Corsair Hydro Series H55 is $69.99 (pictured below).
“The Hydro Series H50 and H60 have a hard-won reputation for delivering effective, reliable, and quiet CPU cooling, said Thi La, Senior VP & GM of Memory and Enthusiast Component Products at Corsair. “These new and improved versions demonstrate Corsairs commitment to providing our customers with the latest and best integrated liquid cooling technology.
