CoolIT Vantage A.L.C. CPU Water Cooler Review
Vantage A.L.C. Temperature Testing Results
With the system running at stock settings the Vantage is keeping the Intel Core i7-930 at 60.75*C with the performance setting. This is 7 degrees off from the Prolimatech Super Mega. The Vantage is also running quieter than the fan I used with the Super Mega. The quieter operation makes up for the temp difference.
With the system running at 3.5GHz the Vantage is still trailing by 7 degrees.
With the system running at 4GHz the heat really gets turned up. The Vantage is still holding that 7 degree gap with the Super Mega.
