CoolIT Vantage A.L.C. CPU Water Cooler Review
Unboxing the Vantage A.L.C.
The box the Vantage A.L.C. comes in is sturdy and has nice images of the unit and points out features and options.
On the next side all the features and specifications are listed.
On the next side there is a bar graph showing the differences in the 3 performance modes.
The last side has simple features listed with a nice image of the unit.
Inside we can see the Vantage A.L.C. is well protected in foam.
In the top of the foam packing are the Intel backing plates and the AMD mounting hardware.
Inside the foam the Vantage is wrapped in plastic.
