Coolit Domino A.L.C. Water Cooler Review
The Test System
CoolIT Systems Domino A.L.C. Water Cooler Installed in the Thermaltake Spedo Advance
Here is the Intel LGA 1366 Test platform:
Intel Test Platform
Component
Brand/Model
Live Pricing
Processor
Intel Core i7 920
Motherboard
ASUS P6T Deluxe
Memory
6GB Corsair DDR3 1600MHz
Video Card
2x Radeon HD 4870X2
Hard Drive
Western Digital VelociRaptor
Cooling
Thermaltake BigWater 760i
Power Supply
Corsair HX1000W
Chassis
Operating System
Windows Vista Ultimate 64-Bit
To test the CoolIT Domino A.L.C. I ran it on our Intel Core i7 test platform, which was then set to run at both default and overclocked settings. As a baseline all coolers will be compared to the retail boxed Intel cooler.
CoolIT Domino A.L.C. Temperatures
All of the temperatures were obtained by using Core Temp v0.99.3 after the system sat at an idle for 30 minutes and then again under 100% load while running Prime95 (64bit) v25.8 for 30 minutes using the in-place large FFTs torture test. The room temperature was kept a constant 72 degrees Fahrenheit (22c) for all benchmarking. All of the coolers were tested with Arctic Silver Lumiere as the thermal interface material.
