Cooler Master N600 PC Case Review
N600 Retail Packaging
Cooler Master has packaged the N600 inside a strong retail oriented box. The front has a very basic feel to it, presenting a view of the case and a few of the features. For a mid-tower case, it measures 8.1 x 17.9 x 18.9 inches (WxHxD), and weighs in at 17.8lbs. However, adding in the packaging and accessories, it takes the shipping weight to close to 21.2 lbs.
While the front of the box shows very basic information, the back provides substantially more. Here a view of the front, interior and back panel are shown with the features of each location pointed out. In addition, at the bottom of the back side the features are listed in eight languages.
The sides of the box look similar to other case boxes. One side provides the specifications of the case, while the other provides little more than a view of the case.
Like most companies, Cooler Master packages the N600 in a plastic bag between two large Styrofoam blocks. While the box might have received minor crush damage, this packaging method kept the case form receiving damage.
As always, Cooler Master makes sure you have the various accessories necessary to install your components. They have included seven sets of tool-less hard drive clips, cable ties, a tiny speaker, security lock, motherboard standoffs (two are already pre-installed), standoff installer bit, and plenty of screws. In addition, a large fold-out user manual is included to aid in the installation.
