Cooler Master Launches Hyper 212 EVO CPU Cooler For $35
Cooler Master announced the Hyper 212 EVO CPU Cooler today, which brings an improved cooling design to the popular Hyper 212 HSF. The improvements to the cooler are rather vast as Cooler Master updated the tower fin design, heat pipe layout, and even upgraded the fans and fan brackets. The best part about the Hyper 212 EVO is that it is still affordable and carries an MSRP of just $34.99! This CPU Cooler should hit retail channels this month well in advance of the AMD Bulldozer and Intel Sandy Bridge-E processor launches.
The cooling system has been redesigned and optimized to provide the best user experience and cooling potential for a new generation of processors. Four Cooler Master patented Continuous Direct Contact (CDC) heat pipes are tightly packed into a flat array on the CPU Cooler base. This acts as a virtual vapor chamber that dissipates a large amount of heat. The aluminum fin structure has been optimized to provide the perfect performance balance between high and low speed fan operations. A high performance 120mm PWM fan with anti-vibration rubber pads and a quick-snap bracket is included. An extra set of quick-snap brackets and anti-vibration rubber pads come standard to give users the option of enabling even greater cooling performance by adding another 120mm fan. The brackets make changing, adding, and cleaning fans an easy task that requires only a few seconds. The included PWM fan can be adjusted via BIOS or OS-based motherboard tuning applications. There is no need to choose between overclocking performance or stock stability, the Hyper 212 EVO and included PWM fan are a versatile pair that tailor noise and performance to any need.
