Cooler Master ATCS 840 Case Review
CM ATCS 840 – Components and External Impressions
View of case, box and pieces
The first thing youll notice when you take the case out of the box is just how massive it is being 9.57 wide and 22.83 tall. This is partly due to the 230mm fans that come pre-installed and also to support six 5.25 drive bays and six 3.5 HDD bays. The case is heavy as well which typically bodes well for the level of craftsmanship used and I can indeed confirm that the case is very sturdy and well built with clean welds and a thoughtful layout.
Side view of CM ATCS 840 case
The next thing I noticed was the beauty of the simple design. No windows, no glowing lights (save for the HDD and power lights), no bezel door and no fancy design patterns. This appeals to me for my PC is not a showpiece and Id rather have those design dollars put towards more functional features. The all aluminum chassis comes in two colors; I opted for the black case but it is also available in silver. The black does tend to collect finger marks on it. This was no big deal to me but some may find it annoying.
ATCS 840 IO panel
The I/O panel on the front pops up with a firm push and can be closed when not in use although I see no reason to keep it closed.
ATCS 840 bottom PSU vent
There is a vent where the PSU mounts allowing the air warmed by the PSU to exit the case without adding heat to the interior. This vent, as well as the one next to it, each have dust filters which are easily removed and washed without the removal of any other parts.
