BFG Tech Launches EX-1000 Modular Power Supply
BFG Technologies will announce the new EX-1000, 1000 watt modular power supply later this afternoon. The EX Series ushers in a new approach to power supply design, utilizing BFGs proprietary Frequency Conversion Technology. Frequency Conversion Technology drastically improves low load efficiency by emulating a lower sized power supply. This allows the EX-1000 to remain at least 80% efficient, even with loads as low as 10% of the units maximum capacity. The EX power supplies have the lowest minimum load requirements and offer the best +5VSB efficiency on the market. The EX-1000 comes with a lifetime warranty, 24/7 tech support and is available now exclusively at select Best Buy stores and online at http://www.bestbuy.com for $199.99
Of the 1627 power supplies currently certified to be 80 PLUS efficient, only 157 (less than 10%) are 1000W or greater, further distinguishing setting apart the EX-1000 from the competition. The EX-1000 was rated higher than the Cosair 1000W, an OCZ EliteXstream, a SilverStone OP1000, and two Enermax 1000W power supplies.
