Be Quiet! Dark Power Pro 10 650W PSU Review
Unboxing the Dark Power Pro 10 650W
The box
Our Dark Power Pro 10 650W unit arrived in a large, strong cardboard box, inside which the power supply is very carefully packed and sandwiched between thick packaging foam. The artistic theme is very dark and serious, obviously trying to make a professional impression.
The box (rear)
Be Quiet! printed a lot of information on the back of the box, from the list of features down to the length of each individual cable, making the packaging itself essentially a basic manual.
Bundled items
A very complete bundle awaits those who will buy a Be Quiet! Dark Power Pro 10 unit as the company included virtually everything they could include with a power supply, with the very minor exception of a case badge. The company provides cable ties, cable straps, a set of five long black screws and another set of five thumbscrews, a bracket with the OCK switch (more on that later), a jumper to bypass OCK and even four cables which provide eight extra 3-pin fan connectors.
Modular cables
Instead of a pouch, Be Quiet! stores the modular cables in a solid cardboard box. The cables are typical color-coded wires covered with ordinary black sleeving. Each bundle is held by a straight cable strap, therefore there are five more straps here than those we counted before. The picture below depicts the length of each cable and the number of connectors.
Cables and connectors
