ASRock 890GX Extreme3 Motherboard Review
Power Consumption
System Power Consumption
Since power consumption is a big deal these days, we ran some simple power consumption tests on our test beds. The systems ran with the power supplies, case fans, video cards and hard drives. To measure idle usage, we ran the system at idle for one hour on the desktop with no screen saver and took the measurement. For load measurements, Prime95’s in-place large FFT’s was run on all cores to make sure each and every processor was at 100% load for maximum power consumption and heat. We also ran FurMark 1.8 at 1280×1024 to put a full load on the graphics card. All systems were tested using as identical hardware.
The MSI 785GM-E65 does pull less power than the ASRock 890GX Extreme3. This can likely be attributed to being a smaller form factor board with less features.
