Arctic Cooling Freezer 13 Pro CPU Cooler Review
Unboxing the Freezer 13 Pro CPU Cooler
The Freezer 13 Pro comes in a plastic clam shell packing.
On the back of the packing there is a chart that shows how the Freezer 13 Pro will improve CPU temps over the stock cooling. There is also a small image showing the idea behind the cross flow fan on the cooler base, as well as a chart with the cooler specifications.
The chart shows a 25.5*C improvement over the stock Intel cooler for a Core i7-920 overclocked to 3.6GHz. That is a very nice improvement over stock cooling.
Those that speak/read a language other than English will have to look on the bottom to find the features list.
With the packing open we can see the accessories are stashed in the very bottom.
The cooler base with the pre-applied MX-4 thermal paste is protected with a plastic tray that also holds the Intel mounting ring.
The accessories are simple. It consists of 2 small baggies for Intel and AMD.
