Arctic Cooling Announces RC Pro RAM Cooler for Overclockers
RAM cooling is crucial for maintaining high clock rates as well as to avoid any damages caused by overheat. In order to offer an efficient tool to lower RAM temperature, the Swiss IT cooling solution provider ARCTIC COOLING today launched the new ARCTIC RC PRO, an advanced RAM cooler designed for DDR2 and DDR3 SDRAM modules. One package contains a pair of ARCTIC RC PRO. This product is available in November 2009. The MSRP is US$ 9.95 and 6.95. I think this is the largest RAM cooler that I have ever seen and to be honest with you it almost looks too big and is a tad ugly.
ARCTIC COOLING RC PRO Ram Cooler
Following the design concept of the award-winning ARCTIC RC, this Pro version also features long aluminium fins as well as highly conductive thermal pads. The fins are extended to 5cm which lead to a significant increase in heat transfer area and optimized natural convection. The pre-applied thermal pads efficiently draw heat out from the RAM to the fins. The ARCTIC RC PRO is securely assembled by 3 screws. By giving high pressure to the two heatsinks, thermal pads will firmly lay on the modules for best heat dissipation. While a generic heat spreader has only limited cooling effect on the RAM, the ARCTIC RC PRO powerfully lowers the temperature by 50%*. Such unparalleled temperature reduction extends the RAM service life and boosts overclocking to a new level.
