ARCTIC Announces the Freezer 13 PRO CPU Cooler
Back in October 2010 Arctic Cooling Freezer 13 and it was a good cooler, but the company wanted to make it bigger and better! That is where they new Freezer 13 Pro CPU cooler comes in. With its four U-shaped 8mm high performance heatpipes and the new cross blow fan it brings up to 300 watts of cooling performance – that’s 100W more than the original Freezer 13 and more than enough for any stock clocked CPU on the market today. The CPU Cooler is compatible with AMD sockets AM3, AM2+, 939 754 and Intel sockets 1366, 1155, 1156, 775. The Freezer 13 PRO comes with a 6 year limited warranty, with a MSRP set at $54.90 USD and 39.90
EUR, excl. VAT.
Superior in its ground-breaking engineering design, the Freezer 13 PRO overpowers its competitors by generating up to 300W of cooling capacity. Featuring an ultra-quiet 120mm PWM-controlled fan with four U-shaped 8mm copper heatpipes, the Freezer 13 PRO is all set for inaudible and massive heat dissipation. The mega-sized CPU cooling fan guarantees adequate airflow through the aluminum fins in the heatsink. Such meticulously engineered mechanism effectively and efficiently transfers the emitted heat away from the core of the CPU.
