Antec Kuhler H20 920 CPU Water Cooler Review
Antecs Chill Control V Software
Once you have your cooler installed you install the Chill Control V Software. This gives you the ability to tweak the Kuhler H2O 920s settings to behave the way you want it to. The Main screen is the Dashboard. This screen shows you what the cooler is doing at that time, as well as Min, Max, and Average values for Pump Speed, Fan Speed, Liquid Temperature, and Sound Level. In the upper right there is what looks like an adjusting knob. This is what switches the performance profiles. There are two preset profiles, and one custom profile the end user can adjust. The sound level meter is not an exact reading, it is similar to software that reads voltages.
The Silent profile runs the Kulher H2O 920 fans at a very quiet 600-900 RPM. In this mode the Kuhler H2O 920 is the quietest of these style self-contained kits.
Extreme mode however is another story. This profile runs the unit full tilt. Everything at 100% and I will say it is the noisiest cooler I have ever had on the test bench. Im talking out of the room and down the hall loud. The range of noise from 920s fans is very interesting to say the least.
Next tab is the Graphs tab. It shows in graph form the Liquid Temperature and Fan Speed.
Third tab is the Fan Control tab. In this tab you can set how you want the fans to behave. The settings are based off of the liquid temperature. You have two settings available to adjust. The first is the ramp up temp, this the point the fans start to spool up to full speed. The next setting is point at which the fans will go full tilt. This cannot be set any higher than 50*C, and a 10 degree separation is the minimum.
The last tab is the Settings tab. Here you adjust the LED color for the logo on the pump housing, or disable it completely. Here you also set start up options, if you want the temps to be shown in Fahrenheit rather than Celsius, and also the skin.
The software comes with two skins. The default skin is Night, the second skin is Ocean, nice for those who are a fan of the color blue.
