Amped Wireless R20000G High Power Dual Band Router Review
Amped Wireless R20000G – Power Testing Results
Power consumption by your homes electronic devices continues to be a very important issue so we have made an attempt to present some simple power consumption tests on the various routers that we had. To measure idle usage, we reset each wireless router to the default settings and plugged them with no devices connected to them. We then measured the power draw from each router at the wall with our P3 International P4400 Kill-A-Watt electric usage monitor.
![Amped Wireless R20000G Power Costs Amped Wireless R20000G Power Costs](/images/reviews/2066/Router_Power.jpg)
Since most people will have their routers turned on for 24-hour a day operation, we think that examining power usage is an important benchmark. Total cost of ownership (TCO) is an important financial estimate that helps consumers direct and indirect costs of a product. In our TCO calculation we will be figuring up how much it costs to have a wireless router running per year in an idle state with the unit being installed 24-hours a day. We will be using 12.7 cents per kilowatt-hour (kWh) based on the bureau of labor statistics report from April 2012 showing that amount as the national average.
Benchmark Results: Power Consumption for the Amped Wireless R20000G Router is very low so that in turn keeps your bills low as you run the router throughout the year. Only the TP-Link TL-WDR4300 and EnGenius ESR750H come close to the R20000G in terms of power cost.
