AeroCool AeroEngine-Plus ATX Case Review
The Aerocool AeroEngine Plus – 440MM of Fan Power
The AeroCool AeroEngine Plus is an attractive mid-tower case with a massive 140mm blue LED front intake fan and an even larger 180mm side fan; and lets not forget the 120mm rear exhaust fan. If you add this all up, it means this case has a grand total of 440mm worth of fans! There are not too many cases out there that can boast this kind of air flow right out of the box, not to mention looking this streamlined. Taking note of recent trends the AeroEngine Plus also has easy access top mounted power/reset buttons along with the audio ports and USB connectors. They kept the front door that helps hide the four 5.25″ drive bays and one 3.5″ drive bay for those of you who don’t have the right color front bezel on your drives. With enough room to mount five hard disk drives directly in front of the 140mm LED fan it means proper cooling for todays 10,000RPM Raptor hard drives by Western Digital that are popular among enthusiasts. We all know talk is cheap and great features don’t mean a solid product, so lets see if the AeroEngine Plus delivers!
Special Features
- USBs + Audio/Mic
- Stylish side panel design (Both side-panels) for excellent ventilation
- 1 x 18 CM side window fan
- Front 14cm fan w/ Quad Blue LEDs
- Side 180mm Translucent Fan
- Screwless sliders for 5 1/4″ devices and HDDs
- High end black thumb screws for the side panels
- Rotated 90 degree HDD cage for easy installation
- Stylish Front Turbine Jet Engine design
- Product Name: AeroEngine Plus BK
Specifications
- Case Type: Mid-Tower
- Material: 0.6mm SECC
- Dimensions: 430(H) x 200(W) x 440(D)
- Motherboards: ATX & Micro ATX
- Drive Bays:
- 4 x 5.25″ (External
- 1 x 3.5″ (External)
- 5 x HDD (Internal)
- Top I/O Port: 2 x USB2.0 Earphone / Mic
- Slots: 7
