ADATA XPG V3 3100MHz DDR3 Memory Review – Worlds Fastest Retail DRAM Kit
SiSoftware Sandra Memory Bandwidth
The Sisoftware Sandra 2012 SP3 benchmark utility just came out a few weeks ago and we have started to include it in our benchmarking. Sandra 2012 comes with support for Virtualisation (Virtual PC/Server, Hyper-V, VMware) and GPGPU (OpenCL, DirectX 11 DirectCompute), but today we will be using the program to look at memory and CPU performance!
Benchmark Results: The Sandra 2014 memory bandwidth benchmark shows that the ADATA XPG 3100MHz memory kit has an aggregate bandwidth of 25.59GB/s while using the XMP settings. Running the memory as fast as I can without the XMP settings, which is at 2933MHz gives an aggregate memory bandwidth of ~25GB/s. Running the XPG 3100MHz at the JEDEC the aggregate performance is only 18.65GB/s.
