ADATA XPG V3 3100MHz DDR3 Memory Review – Worlds Fastest Retail DRAM Kit
ADATA XPG 3100MHz Memory Kit Overclocking
Overclocking greatly varies due to what hardware is being used and who is doing the overclocking. Always remember that no two pieces of hardware will perform the same, so our results will differ from what you might be able to get.
ADATA XPG 3100MHz Memory Kit 3100MHz Settings
The ADATA XPG V3 3100MHz memory is pushing the limits as is running at 3100MHz. I wasn’t sure how much more I would be able to squeeze out of the XPG V3 memory, but I won’t know unless I try!
ADATA XPG 3100MHz Memory Overclocking
It took some time, slowly increasing the Bclk of the system but ultimately I was able to squeeze out an additional 100MHz from the ADATA XPG V3 memory! The tRCD and tRP timing increased to 15 but everything else was left as is.
adata-xpg-3100mhz-mem-3200mhz-2
In order to hit 3200MHz on the ADATA XPG V3 3100MHz memory kit, I increased the Bclk to 133.52MHz. I also dropped the CPU Multiplier to x31 to keep the CPU Speed constant as close to the XMP profile as possible.
