BitFenix Announces Neos and Neos WIndows PC Cases
What do you get when you combine serious style and robust features with an ultra-competitive price point? You get Neos – the latest chassis design from the BitFenix Labs!
Here are just some of the highlights:
– Play with Color Available in multiple color combinations to suit any environment
– Simply Stunning Simple and clean design with enhanced airflow for cooling system components
– Window Option Available Show off the components inside
– Plentiful Storage Three 3.5 HDD and three 2.5 SSD locations provided
– Fits Long Graphics Cards Fits long graphics cards up to 30cm in length
– SuperSpeed USB 3.0 Transfers at speeds up to ten times that of USB 2.0
– Trouble-free Installation Tool-free drive locking, removable dust filters and CPU cutout
– Tremendous Value Robust features at an extremely competitive price
For more details, check out the attached press release and image gallery below.
Keeping Cool
Of course, the mesh itself is not merely cosmetic. A closer look reveals extra-large holes that allow for unencumbered airflow to system components. At the same time, this mesh design allows the negative space behind it to actually become a part of the overall design, providing a subtle yet appealing design element to the case.
Want to add more bling? Simply install LED fans to the front panel, and you’ve created yet another exciting look. A window version of Neos is also available should you want to show off your system components. With its elegant yet simple styling, Neos is a blank canvas for you to create your own masterpiece.
Tremendous Value
On top of all of this, Neos was designed with first-time builders and value-seekers in mind. Niceties like removable dust filters, tool-free drive locking, all black cabling, and even an aluminum BitFenix logo badge have all been included. When it comes to offering value, Neos is one chassis that punches well above its weight.
Specifications
Specifications
Neos
Neos Window
Materials
Steel, Plastic
Colors (Int/Ext)
Black/Black, White/White
Dimensions (WxHxD)
185mm x 428.55mm x 470.5mm
Motherboard Sizes
Mini-ITX, Micro-ATX, ATX
5.25″ Drive Bays
x 2
3.5″ Drive Bays
x 3
2.5″ Drive Bays
x 3
Side Panel
Solid Steel
Windowed
Cooling Front
120mm x 2 (optional)
120mm x 2 (1 x LED fan included)
Cooling Rear
120mm x 1 (included)
PCI Slots
x 7
I/O
USB 3.0 x 1, USB 2.0 x 1, HD Audio
Power Supply
PS2 ATX (bottom, multi direction)
Extras
Removable front and bottom dust filters, tool-free drive locking, all black cabling
Model
P/N
EAN
UPC
Solid Side Panel
Neos Black/Black
BFC-NEO-100-KKXSK-RP
4716779445053
886027003510
Neos Black/Blue
BFC-NEO-100-KKXSB-RP
4716779445060
886027003527
Neos Black/Red
BFC-NEO-100-KKXSR-RP
4716779445077
886027003534
Neos Black/Silver
BFC-NEO-100-KKXKS-RP
4716779445084
886027003541
Neos White/White
BFC-NEO-100-WWXKW-RP
4716779445091
886027003558
Neos White/Blue
BFC-NEO-100-WWXKB-RP
4716779445107
886027003565
Neos White/Red
BFC-NEO-100-WWXKR-RP
4716779445305
886027003572
Neos White/Silver
BFC-NEO-100-WWXKS-RP
4716779445312
886027003589
Window Side Panel
Neos Window Black/Gold
BFC-NEO-100-KKWKA-RP
4716779445343
886027003626
Neos Window White/Purple
BFC-NEO-100-WWWKP-RP
4716779445350
886027003619
BitFenix Neos will be available on store shelves in May.
About BitFenix
BitFenix is the result of the collaboration of several veterans in both the technology and gaming industries. From the same minds behind some of technologys most venerable products, BitFenix creates hardware and peripherals that grant the user the utmost control, strength, and performance to complete their computing tasks. Combining a deep understanding of gaming and other high-demand computing applications with superior engineering and design know-how, the BitFenix Team is dedicated to creating the go-to computing products and peripherals for those who refuse to quit.
