ABS Tigas Super Full Tower Chassis
Moving Inside the Tigas
ABS Tigas back plane PCBs
Pulling the side panel off, we can get a look at the inside of the Tigas. Towards the front we have the drive cage back plane PCBs, and the center video card support. There are 5 molex connectors that power the 10 drives; each drive has its own SATA connector. The center expansion card support may not be able to be used by all. The support parts require it to mate up to the expansion cards PCB. Most cards these days have a housing of some kind enclosing it.
ABS Tigas PCB for the drive bays
Behind a cover plate on the right side of the drive cage is the PCB for the drive bay power switches as well as the door fan speed controller.
ABS Tigas 5.25 bay tool-less rail
The top 5.25 bays are tool-less. The 5.2 device is held in place with pins, vibration dampening is provided by a rubber pad in the center of the retention bracket.
ABS Tigas rear 120mm exhaust fan
Looking to the back we can see the rear 120mm exhaust fan as well as the 7 vented expansion slot covers.
back side of the ABS Tigas motherboard tray
With the left side of the case off we can see the back side of the motherboard tray and another removable cover panel like on the right side.
ABS Tigas wire cover
This one covers up the front I/O cabling. All the cables are long enough to reach the motherboard connections, except the audio cable. If it could have been another good 6 to 9 inches longer would have been much nicer for achieving the clean look.
ABS Tigas removable motherboard tray
The motherboard tray is also removable. This is nice for mounting the motherboard and CPU cooler out of the case.
ABS Tigas removable hard drive cage
At the top of the case is a removable hard drive cage. This cage can be used at the top, bottom, or removed completely.
ABS Tigas removable hard drive cage tray
Each tray supports both 2.5 inch and 3.5 inch hard drives. So if your system has SSDs you have an option available to you for mounting your drive. If youre wondering to yourself if the tray will work in the front drive bays with a 2.5 drive, no, the drive is centered on the tray, so it will not line up correctly with the back plane connections.
