8-way SLI and Crossfire Power Supply (PSU) Roundup
AeroCool’s Zerodba 620W
AeroCool’s Zerodba 620W power supply offers Ultra-silent operation with high performance. This unit is also a modular power supply which means you can better manage your cables by plugging in the lines you need to use. Almost all power supplies have a cable or two that you just don’t need to use and with modular power supplies, you can eliminate that lingering cable altogether. This PSU is considered ATX 12V 2.02 compliant, so you know it is compatible with today’s current platforms.
Feature List
- Fan: 13.5 cm Ultra-silent fan
- Dimensions: 15cm (W) x 8.6cm (H) x 15.8cm (L)
- Modular: Yes
- Cable sleeving: Yes
- Number of 12V rails: 2
- PCI Express, SLI, Crossfire, and Dual CPU ready
- EPS 12V and ATX 12V 2.02 compliant
- Protection technologies: IP, OVP, OPP, SCP
Unique Features
Zerodba: AeroCool’s Zerodba technology consists of an ultra-silent fan, with a 4-step speed switch. The ‘Auto’ setting will start rotating the fan when the system is powered on, the ’50C’ setting will start rotating the fan when the PSU temp is between 45C and 50C, the ’60C’ setting will start rotating the fan when the temp is between 55C and 65C, and the ’70C’ setting will start rotating the fan when the temp reaches above 65C.
3-pin Fan Modular Connections: This power supply ups the other modular power supplies by offering three 3-pin fan connections right on the power supply. This is a great feature for those of you who have a motherboard with limited 3-pin fan headers!
Pricing
Out of all the power supplies in this article, the AeroCool Zerodba 620W comes in at a very competative price of $118.99 at the time of publication. Provided this PSU performs up to standards, this PSU would be one of the better deals of the bunch as the price range of all the PSU’s tested in this article is $89.99 to $219.99!
