Zalman ZM-F3-FDB & ZM-SF3 120mm Cooling Fan Review
Testing the Zalman Fans
Today we’ll be testing 4 Aspects of these fans:
  • Sound Pressure Level (recorded in dBA)
  • Airflow (recorded in CFM)
  • Static Pressure (recorded in mmH20)
  • Heat Tolerance (testing done at 30*C)
The Testing Equipment that I will be using was purchased by me and it includes:
  • Dwyer Differential Pressure Gauge Model 2000-00 AV
  • General Tools DCFM8906 Digital Air Flow Meter
  • Tenma Digital Sound Level Meter
  • Kintrex IRT0421 Non-Contact Infrared Thermometer
  • Universal Enterprises DM383B Digital Multimeter
Today we will be testing these fans against some other fans of my collection to give a comparison against fans offered by the competition.
These are all fans like the Zalman which advertise as being silent solutions with the same 20-25dB(A) range of sound pressure. From left to right: Deep Cool UF120 (reviewed here before), Thermalright TY-140 (uses 120mm fan mounting), Zalman ZM-F3-FDB, Zalman ZM-SF3.
Now onto testing.
Well, here is an interesting point to add, I really have no baseline to go with as Zalman does not list CFM ratings. I also realize that it’s hard to tell what numbers are what on this graph because of the over-lap from the fans so I will add a chart for you to read, as well.
Airflow in CFM
Fan Model Airflow @ 5v Airflow @ 7v Airflow @ 12v
Deep Cool UF120 28.33 39.7 68
Thermalright TY-140 29.16 40.83 70
Zalman ZM-F3-FDB 25.58 35.84 61.4
Zalman ZM-SF3 24.58 34.88 59.8
Now what can we really obtain for these airflow readings? Well, these fans push less air than the competition by only 10 CFM less. Now, this is not necessarily a bad thing; if the fans are quieter than they are really doing their job.
Let’s see the noise level testing now.
Sound Pressure in dB(A)
Fan Model dB(A) @ 5v db(A) @7v dB(A) @ 12v
Deep Cool UF120 15 23 27
Thermalright TY-140 19 21 24
Zalman ZM-F3-FDB 14 18 23
Zalman ZM-SF3 13 17 22
I always like to give a bit of a subjective input on the sounds of these fans so I’ll give a quick overview between our two test subjects today.
Zalman ZM-F3-FDB
Here we have a good example of the Fluid Dynamic bearing and how quiet it can be. At 5v & 7v this fan is absolutely silent. It’s much lower than the 20dB(A) testing environment I am in. For all intents and purposes it is inaudible. Although I can say there was a small rubbing noise present, I had to actually hold the fan to my ear to hear this. At full 12v, this fan was still quiet enough to not be noticeable while running.
Zalman ZM-SF3
I can really see the Everlasting Quiet Bearing shine here. I cannot say I can hear it. The sound profile of this fan is so quiet that I cannot tell when it’s running. This is very indicative of the “Shark-Fin” design of the blades actually working. Unlike the F3-FDB, this fan had no noise from the motor nor that rubbing sound I experienced.
Static Pressure in mmH20
Fan Model Testing @5v Testing @ 7v Testing @ 12v
Deep Cool UF120 0.9 1.4 1.9
Thermalright TY-140 0.769 1.1 1.89
Zalman ZM-F3-FDB 1.1 1.54 2.65
Zalman ZM-SF3 1 1.4 2.4
Well, for those of you who do not know what static pressure is or what these numbers mean I’ll break it down pretty easily. Static Pressure is similar to an efficiency rating on how effectively a fan can move air through a restrictive surface like a Hard Drive rack, Fan Grill, Heatsink, or Radiator.
Generally speaking, you wish to see fans in the 2 mmH20 and greater range for heatsink & Radiator use when at full speed. Though normally, “quiet” or “silent” fans lack static pressure because of their blade design and thus are not suited for use on a radiator or heatsink.
Zalman has an impressive showing, though, with a good and quiet fan that can also be adapted for other uses besides a standard case fan. Call me impressed but I definitely was not expecting this when I was giving the visual exam of the fans on the last page.
Let’s wrap this up and we’ll see where everything stands; shall we?
