Thermaltake Water2.0 Pro CPU Cooler Review
Thermaltake Water 2.0 Pro 120MM Dual PWM
Thermaltake has been around for as long as I can remember. Over the years they have made just about every accessory for a PC. They have even done water cooling. In the past Thermaltake had the Big Water series, a user assembled kit that took a couple of 5.25″ drive bays and could be expanded on. Then came the Pro Water series, which was also a user assembled kit that mounted in a more traditional way like most custom water loops. Both the Big Water and Pro Water kits where expandable, so GPU water blocks and extra radiators could be added to the loop.
Now Thermaltake has teamed up with Asetek and brought the Water2.0 line to market. The Water2.0 line consists of 3 All-In-One sealed water coolers.
  • The Water2.0 Performer, a slim 120mm radiator cooler with twin fans.
  • The Water2.0 Pro, a thick 120mm radiator cooler with twin fans.
  • The Water2.0 Extreme, a thin 240mm radiator with twin fans.
We recently looked at the budget friendly Water2.0 Performer that retails for $62.99 shipped and found it to be a very good cooler for the money. Today we have the Water2.0 Pro for you to take a closer look at. The Water2.0 Pro runs $98.91 shipped and features a double thick 120mm aluminum construction radiator with twin 120mm fans in a push/pull arrangement. The Thermaltake Water2.0 Pro costs 57% more, so it will be interesting how much better performance will be.
Thermaltake Water2.0 Pro fan
The fans are PWM controlled and operate between 1200 to 2000 RPM pushing a max of 81.3CFM @ 27.4dBA.
Thermaltake Water2.0 Pro base
The water block is all copper and the pump is connected to the radiator with flexible black rubber tubing.
Features of the Thermaltake Water 2.0
  • Pro
    Powerful and Robust Pump Maximizes the Liquid Cooling Circulation. No Refill Needed.
    High performance Copper base plate accelerates the heat conductivity.
    High reliability low profile pump provides quick liquid circulation lowering the temperature.
    Pre-filled coolant reduces the liquid replenishment hassle.
    Low evaporation tube decreases the loss of coolant effectively.
    The high-tech sealed circulation system prevents leaking issue.
  • Thicker Radiator Benefits from the Larger Cooling Surface
    Powerful fan blows the heat of radiator out to the chassis to maximize cooling performance.
    Dual Automatic Adjustable 120mm PWM Fans maximize the cooling performance and tranquility.
    PWM control function fan (1200~2000rpm) automatic adjust the fan speed according to CPU temperature, minimize overheating possibility.
  • Universal Socket Compatibility & Accessory Package
    Universal socket support:
    Intel: LGA2011, LGA1366, LGA1156, LGA1155,
    AMD: FM1, AM3+, AM3, AM2+, AM2
Specifications of the Thermaltake Water 2.0 Pro
  • P/N: CLW0216
  • Pump
  • Motor speed: 2800+-150 RPM
  • Rated Voltage: 12V
  • Rated Current: 220mA
  • Fan
    • Dimension: 120 x120 x 25mm
    • Speed: 1200~2000RPM
    • Noise Level: 27.36dBA(Max)
    • Rated Current: 0.5A
    • Max. Air Flow: 81.32CFM
    • Connector: 4 Pin
  • Radiator
    • Dimension: 149.9×119.9×48.8 mm
    • Material: Aluminum
  • Tube
    • Length: 326 mm
    • Material: Rubber
  • Weight: 1,060g
  • Compatibility
    • Intel: LGA 2011, 1366, 1155, 1156, 775
    • AMD: FM1, AM3+, AM3, AM2+, AM2
    Let’s move on to the next page where we can take a look at the retail packaging and then take a closer look at this CPU cooler.
