Thermaltake Water 2.0 Performer CPU Water Cooler Review
Intel Core i5 2500k Test System
Today well be comparing the Thermaltake Water 2.0 Performer
against a few other coolers that weve previously tested.
Processor Intel Core i5 2500k
Motherboard Asus Sabertooth P67
Memory Corsair Vengeance 8GB DDR3 1600MHz
Video Card EVGA GTX 470
Hard Drive Curcial C300 64GB SSD
Case Cooler Master HAF 932
Power Supply BFG Tech EX-1000
Operating System Windows 7 Home Premium X64
Core i5 2500k Test Specs
Here you can see the clocks and voltages that the system
will be using for the overclocked tests.
For monitoring all temperatures I am using RealTemp. For
idle temperatures, the computer was left unused for 15 minutes at desktop
allowing it to settle. For load temperatures, prime95 was used, and ran for 20
minutes using the default blend setting. The CPU was tested at stock speeds
with turbo enabled. Our overclocked tests were run at 4.8 GHz using 1.46v to
maintain stability. All tests are done using Arctic Cooling MX-2 thermal
paste. Temperatures shown will be the
average of all four cores. For those who are curious, the ambient room
temperature is right at 74 degrees Fahrenheit or 23.3 degrees Celsius.
