Thermaltake Water 2.0 Performer CPU Water Cooler Review
Jump To:
Looking closer at the Water 2.0 Performer
Thermaltake Water 2.0 Performer Radiator
Taking a look at the radiator for the Water 2.0 Performer,
it seems like a pretty standard 120mm water cooling radiator.
Thermaltake Water 2.0 Performer Pump
This is the pump and waterblock for the Water 2.0 Performer.
You can see that it has a standard 3 pin connector, for connecting to your
motherboard’s fan header. You can also get a glimpse of the mounting notches
that the Water 2.0 Performer uses.
Thermaltake Water 2.0 Performer Pump Height
Here is a look at exactly how tall the pump/waterblock combo
is. Without the plastic cap protecting the base of the water block, it would be
right at the same size as the included 120mm fans, which are 25mm thick.
Thermaltake Water 2.0 Performer Pump Base
The base on the water block is flat, and comes with
pre-applied thermal paste.
Thermaltake Water 2.0 Performer Fans
Included are two 120mm fans, both of which feature a PWM 4
Pin connector.
Here you can get a closer look at one of the fans that are included. They are both the exact same, and are model PLA12025S12HH-LV, which appear to be specific to Thermaltake’s heatsink lineup.
Jump To:
