Thermaltake Frio OCK CPU Cooler Review
Temperature Testing
Here we can see that the Frio OCK was not only cooler on the high fan setting, but also on the low setting. I was expecting it to best the other two on high, but on low I wasnt too sure what the outcome was going to be. Coming in at just 42 degrees Celsius on high and 45 degrees Celsius on low is very respectable and bested all of the other coolers it was compared against.
When the CPU was overclocked to 4.8 GHZ you can see that this is where the Thermaltake Frio OCK really shines. It was considerably cooler on both high and low fan settings than either of the other two tested coolers, keeping the CPU at 67 degrees Celsius on low and 64 degrees Celsius on high. On the high fan speed setting, I was thoroughly surprised by how well this cooler was performing. I also wasn’t expecting anything close to the temperature results on low either! The Thermaltake Frio OCK performed much better than the other coolers that I have for comparison right now.
