Thermaltake DIY Water Cooling Parts Now Available at Newegg
Thermaltake-Liquid-Cooling-Parts
At CES 2015 our friends over at Thermaltake unveiled new DIY water cooling kit parts. We just found out that those new pumps, reservoirs, and water blocks are in-stock and available to purchase on Newegg!
The rather unique looking Thermaltake Pacific P1 Black D5 pump (part number CL-W026-PL00BL-A) is the heart of the new DIY part line and retails for $189.99 shipped. This pump was built to be silent yet have a lifecycle of 50,000 hours, which means you should get about 5-years of use out of it. The 1135 liters per hour pump uses standard G 1/4 fittings, connects to a PSU using a standard 4-pin header and has a built-in manual speed controller that allows you to run the pump at five different pre-set speed steps that range from 1800 RPM all the way up to 4800 RPM.
Pacific PT40
If you didn’t want to go with something like that there is the Thermaltake Pacific PT40 water reservoir/pump combo that runs $79.99 shipped. For 80 bucks you’ll get a resoviour that can hold 400ml of your favorite coolant and get a pump that is rated at 500 liters per hour. You also getting the mounting bracket.
tt-pacific-parts
Thermaltake also has some pretty sexy chrome compression fittings, fill-port fittings, 90 degree adapters, G1/4 connector blocks, barbs, extenders, water blocks, radiators, reservoirs, tubing and even coolant. Be sure to check out the Thermaltake DIY Water Cooling landing page at Newegg to see all the options you have for a custom water cooling loop! All of the items offered in Thermaltake’s Pacific DIY water cooling product line are backed by a 1-year warranty.
Thermaltake Pacific RL240
If you don’t want to piece together your own kit you can always buy the Thermaltake Pacific RL240 Water Cooling Kit that comes with one CPU water block, one D5 pump and reservoir, one 240mm radiator, six compression fittings (chrome), two Luna 12 LED red fans, tube, red coolant, and other accessories for $299.99 shipped.
