Thermaltake Bigwater 760i Water Cooler Review
Jump To:
The Packaging
The Bigwater 760i system comes well packed in a large box. The box front has images of the drive bay unit and the water block.
The back of the box has more images and information about the features of the system.
When you first open the box there is a subtle note from Thermaltake that would be in your best interest to run a pre-install test or leak test out side of the system. We can also see the UV reactive tubing, manuals, and accessory box.
Underneath is the drive bay unit, coolant, fill bottle, and water block; all snugly packed in foam.
Inside the accessories box is the mounting hardware, backing plates, and the female quick disconnect fittings.
Jump To:
