Thermaltake Announces Riing RGB High Static Pressure Radiator Fan
Who Says You Cant Have it All?
New Thermaltake Riing RGB High Static Pressure Radiator Fan
With Patented LED Ring At COMPUTEX 2015
Riing-RGB
Taipei, TaiwanJune 3, 2015Thermaltake, a leading brand in PC Modding solutions, chassis, power supply units, and cooling systems, introduced the new Riing RGB High Static Pressure Radiator Fan at COMPUTEX Taipei 2015 at Taipei World Trade Center Nangang Exhibition Hall 4th floor, Booth M110. The patented circular multicolored 120mm radiator fan is fitted with blades optimized to enhance static pressure for an impressive cooling performance. Hydraulic bearings for silent operation guarantee ultra-low noise, and the anti-vibration mounting system strengthens the products stability during operation. The color and brightness uniformity of the multicolored LED ring is visible from all directions and adds style to the chassis. The New Thermaltake Riing RGB High Static Pressure Radiator Fan will be available in July!
More Details about Riing RGB High Static Pressure Radiator Fan:
Color-Changing Fan Controller
A self-contained fan controller can switch between 5 modes in the combo LED: red, blue, green, white, and multicolor. In multicolor mode users can pause to choose and automatically save the preferred color gradient. To change colors disable the LEDs by switching from ON to OFF mode, or reboot the PC.
Concentrated Compression Blade
Custom designed for high static pressure requirements of demanding applications such as radiators, the concentrated compression blade is engineered to focus the weaker, inner circle of air outward, allowing the outer section to pressurize the air.
Wind Blocker Frame
The wind blocker frame is designed to work with the concentrated compression blades pressure mechanism by directing airflow toward the middle section of the blade, thereby creating a compression effect. The containment of pressure in turn reduces the blades noise and vibration, creating a perfect balance between power and sound.
Hydraulic Bearing with Low-Noise Design
The hydraulic bearing self-lubricates with a high-quality, friction-reducing substance, which lowers operating noise and improves efficiency. The seal cap prevents leakage of the lubricant and improves the lifespan of the unit. The low-noise cable can reduce the noise level by 21% to 24%.
Anti-Vibration Mounting System
In-mold injection anti-vibration rubber pads provide a hassle-free usage with 80% protection coverage for all corners.
